Ir para o conteúdo principal
Lançado em 22 de novembro de 2005, o controle sem fio Xbox 360 é o principal controle de jogo para o console de jogo Microsoft Xbox 360.
Clicking left stick in also clicks right stick?
Kind of a bizarre issue I'm having, but I have a controller where if I click the left stick in it also sometimes registers the right stick being clicked in at the same time. I first noticed it in call of duty when I kept trying to sprint but would crouch or go prone instead. Tested it on PC using the wireless receiver and a controller tester and it does indeed show up as the right stick being clicked in occasionally. I've taken it apart already and given everything a good clean but it's still happening, any ideas on what could cause something like this? I realise it's a pretty weird issue but if anyone has any advice it would be helpful, thanks :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
This is weird indeed.. I would start with replacing the joystick for a new one and see what happens.
I think this will be an easy test to see if it solves it!
Guide: Substituição da alavanca analógica esquerda do controle sem fio do Xbox 360 (yes this is for the left side, the process for the right side is the same).
Please let us know how that goes!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
UndercoverDylan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 30
Ao todo: 172
