Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Perguntas Visualizar todos
Pergunta encerrada
Upper right corner doesn't respond + glue doesn't stick
I just repaired an iPod Touch 4G and everything went great apart from two things:
  • The upper right corner doesn't seem to respond on touches
  • When reassembling, the front panel won't stick together. I used 3M tape, but it doesn't seem strong enough to keep both parts together
Any suggestions/tips?
Thx!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like the screen you used has a defective digitizer.
When I repair these iPods I usually use a head gun to lightly warm the outer edges of the new glass once it is installed to "melt" the adhesive and then I put the iPod on a flat surface on a microfiber towel and then put a couple of heavy books on top. It always gives it a better stick!
Also, check to see if that top corner is dented or bent. That can always make a difference too
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 545
