My charger is not charging my laptop
There is a teared part near the the 6-pin,and every time I try to charge it doesn't work
Esta é uma boa pergunta?
If the 6-pin area is already damaged, you should stop using it immediately.
This could cause a short circuit.
If a short circuit occurs, it could potentially damage your Surface Book as well.You should not use it anymore. Replace the charging cable.
To prevent this issue in the future, you can use electrical tape near the 6-pin connector on your new cable as a form of protection.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 154
@tonyman36000 let's see what the damage looks like. Post some pictures of that with your question so we can see what you see and hopefully help you to fix your cable. Adicionar imagens a uma pergunta já existente
por oldturkey03 Compartilhar
