Ir para o conteúdo principal
A1708/EMC 3164 — Lançado em junho de 2017, este MacBook Pro de entrada mantém as teclas de função tradicionais (em vez da Touch Bar OLED).
No power or fan spin but charging port gets warm
I had a macbook with what i thought was just a dead logic board, but upon replacing it the computer still doesnt boot. With the known working board, it does get warm around the charging port which the previous motherboard did not. I have tried a pram and smc reset, no changes.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I would definitely check the charger the other problem could be on the main power rail for your Mac. I believe it’s called the G3 line on the schematics.
por Compartilhar
Adicionar um comentário
1 resposta
The fact the USB-C port is warm tells us power is getting in, but the charging logic is not dispatching the power to the battery. This series is very dependent on its BMC cable to work, review Steps 10~13 in this guide Substituição da bateria do MacBook Pro 13" com Function Keys de 2017 make sure the ZIF connector latches are compressing the ribbon cable. Often I encounter the latches have jumped out when unlatching or not latched down. Sometimes the cable gets damaged so it needs replacing.
While you did try a second board the power connector as described in Steps 14 & 15 can be damaged by bending it back to far the guides image shows lifting it about 45 degrees which is too much without risking it, I just lift it about 10 degrees and place a piece of card stock between setup as a cap held together with some tape.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
2048Megabytes será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 167
