Is it worth putting in an SSD boot drive?
Is it worth putting in an SSD boot drive in this machine? My optical drive is shot and I've read that installing an SSD boot drive, then putting the old HDD in the optical drive position (inside a converter bracket) is the way to go. This is a 2006 machine. Any recommendation as to SSD?
Or with this old a machine, would I get just as much speed if I were to install, say, a 7200 rpm drive in place of the original 5400 rpm HDD?
Thanks!
Update
And, I believe I can get an older SSD since my A1150's HD bus is running at 3Gb/s, or am I mistaken about that?
Esta é uma boa pergunta?
3 comentários
I ended up buying a 6G SSD and making it my main drive. I was going to get an adapter for the optical drive bay (since my drive wasn't writing), but I took the drive out, took it apart, sprayed it with air, and now it works perfectly. I know the 6G isn't utilized by my machine, but I can use it in my next mac. In the meantime, I have the fastest A1150 Macbook pro possible for $150 in parts.
por crubeo66
crubeo6611- You've put a comment where only Answers belong.
por originalmachead
I have the same computer what hard drive and memory did you buy?
Dave
mgbrv8@yahoo.com
por mgbrv8
