Ir para o conteúdo principal
A Radeon RX 560 é uma placa gráfica de gama média da AMD, lançada em 18 de abril de 2017. Fabricada no processo de 14 nm e baseada no processador gráfico Polaris 21, na sua variante Polaris 21 XT, a placa suporta DirectX 12.
My graphics card heats up significantly when I enter any games
I enter the game, and after about ten seconds, the game freezes, while the graphics card begins to overheat and make excessive noise. Occasionally, the computer shuts down on its own to prevent damage to the graphics card, but it seems that it may already be broken. The issue might lie with the thermal pads, as I do not have any. The problems started after I disassembled it and replaced the thermal paste; everything was functioning normally prior to that. Please assist me.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi! I just looked up some random disassembly videos on Youtube for your graphics card and could not see any thermal pad. So if you did not remove any thermal pads, then a lack of thermal pads is probably not an issue.
I presume that you've cleaned your graphics card from dust and similar as you've disassembled it.
Can you monitor what exactly that's overheating? Can you see any specific sensor more than just "graphic card"? This can sometime be done with HWMonitor or HWiNFO.
Are you sure that you've covered the whole GPU die with thermal paste? (better with too much thermal paste than too little)
por
Adicionar um comentário
1 resposta
Do you mean you didn't replace the thermal pads or you didn't put any on? Without the thermal pads to conduct heat away the VRAMs(those black rectangular chips around the GPU die) would literally cook themselves. If you left the old ones on the VRAM, then it's a very good time to replace them, as they're obviously not doing their job. Can you take apart your card again and post some pictures so we can get a better idea?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Саша Белый será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 216
