Ir para o conteúdo principal
O Wii Remote é o controle principal e original do console de jogo Nintendo Wii, lançado em 19 de novembro de 2006. O número de modelo do Wii Remote original é RVL-003.
Normal functionality besides the Home, Minus, and Plus buttons
Hello, I recently acquired some old wiis and a corroded wii remote. I opened up the wii remote and did a complete clean of the entire board and battery terminals. Everything seems to be fine with the rest of the remote but the middle three buttons have no functionality. Any insight into a possible fix would be amazing.
Here is the board for reference
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Yeah, most likely something on the motherboard and it won’t be an easy fix…
Not sure which component failed there… you can try replacing one button and see if that will do something, but I doubt it. The corrosion must have damaged something on the board.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Well I guess I'll just be grateful that it turns on it all and has part functionality, I separated the yellow membrane from the actual button and cleaned it as well but to no avail. I have no soldering skills so replacing a button is currently out of reach, but thank you for the suggestion.
por Compartilhar
My pleasure! Then the only fix will be replacing the motherboard (which is basically the controller) or ask a repair shop! Sorry
por Compartilhar
Adicionar a sua resposta
Jacob H será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 293
