Ir para o conteúdo principal
The iPod Seventh Generation, marketed and sold as the "iPod Classic", was released in September 2009, and did not have any visible differences compared to the previous version. It simply replaced the previous 120GB iPod Classic 6.5 with a thin 160GB version.
Schematic diagram or Component list
I have a 7th gen classic where this capacitor fell off the motherboard, and i lost it
does anyone have schematics or any idea of what value piece this is supposed to be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly, Apple dipped the official schematic for the 7th-gen Classic, but based on the pad size, layout, and the surrounding components, that spot is almost certainly one of the small decoupling capacitors on the power rail. On these boards it’s typically a 0.1 µF (100 nF) 0402 ceramic cap.
I can’t say 100% without a donor board to measure, but the layout matches the standard bypass caps Apple uses all around the SoC. A 0.1 µF 0402 MLCC (6.3V or higher) should be a safe and correct replacement.
Still, i recommended you get a doner board (like 10 bucks) to be absolutely sure because its been 2 weeks since i last repaired a 7th gen classic
Esta resposta foi útil?
Pontuação 2
3 comentários:
thanks for the answer! where do you get donor boards that cheap all i can find is like 70€ type price?
por
@pedererasm22768 from facebook marketplace or ebay and flea markets
Just type up ipod classic 7th gen for parát and full units sell cheaper then only the board
Flea markets a bit tricky, but easy here in vietnam
Ps: cute cat
por
Adicionar a sua resposta
Pedroto3 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 49
Últimos 30 dias: 49
Ao todo: 49
