Ir para o conteúdo principal
Repair guides and support for laptops manufactured by MSI.
Problem with blue screens and watchdog violation 0x133 on MSI Katana
Hello!
I’m dealing with a strange issue on my MSI Katana 15 B12VGK. About a year ago I started getting blue screens while playing games like Zenless Zone Zero or Genshin Impact. At a random moment the game freezes on one frame, and after 2–3 minutes the laptop crashes and shows a blue screen with the error “DPC_WATCHDOG_VIOLATION 0x133.”
This only happened in those two games, so I assumed it was an optimization issue. I could play games like The Witcher 3 or Cyberpunk 2077 without problems.
Recently I decided to finally fix the issue. I contacted the support teams for the games and MSI. I tried the following:
  • Reinstalling drivers
  • Installing the stable drivers from MSI’s website (this actually made the BSODs more frequent)
  • Cleaning and repasting the laptop
  • Installing new RAM
  • Updating the BIOS
  • Turning on discrete GPU mode in MSI Center
  • Setting maximum performance for the GPU in the Nvidia Control Panel
Nothing helped. So I decided to try using AI for advice (not the best idea, but I was desperate). It suggested disabling C-states in the BIOS and turning off ASPM. It also claimed that my SSD (Micron 2400) was too slow and unstable, and that giving it more power might help.
These changes helped a little, but didn’t solve the problem. I still get freezes, but now without BSODs — instead, the laptop just reboots after freezing for about two minutes. The freezes also happen less often now. However, recently the same issue appeared in Spider-Man: Miles Morales, so it’s clearly not limited to just two games.
I don’t have the budget to buy a new SSD right now, especially since I’m not sure it will fix the issue.
I’m including a Google Drive link with my system information, two GPU-Z logs (one before following the AI advice, one after), Windows minidump files, and WhoCrashed reports: https://drive.google.com/drive/folders/1...
Thank you for any help.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Hi @arseni79787
Check in Event Viewer for any Critical, Error or Warning events that may be logged at the time the problem occurs.
Also check for any events that have a lot of entries as well as it may give some clues as to what is happening.
por
So every time crush occurs i have this two errors: volmgr162 and kernel-power 41 (63). Here are logs:
Log Name: System
Source: volmgr
Date: 30/11/2025 13:58:44
Event ID: 162
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: ARSPIATR
Description:
Dump file generation succeded.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08...>
<System>
<Provider Name="volmgr" />
<EventID Qualifiers="4">162</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2025-11-30T12:58:44.0571349Z" />
<EventRecordID>287847</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="448" />
<Channel>System</Channel>
<Computer>ARSPIATR</Computer>
<Security />
</System>
<EventData>
<Data>\Device\HarddiskVolume3</Data>
<Binary>000000000100000000000000A2000400B50C0000000
por
Adicionar um comentário
3 respostas
The DPC_WATCHDOG_VIOLATION (Stop Code 0x133) happens when Windows detects that a Deferred Procedure Call (DPC) or Interrupt Service Routine (ISR) has run too long, or the system has spent excessive time at a high interrupt level. In plain terms, it usually means a driver, hardware, or firmware component is misbehaving and not completing tasks within the expected time frame.
There are a couple of DPC monitor programs. They will show how bad it is but don't tell what is causing bad DPCs.
The Event ID appears to be related to saving the dump file after the fact. Both the DPCs and the event ID seem to point to a drive issue.
My first task would be to run chkdsk on all the drives.
then run sfc /scannow
If that doesn't clear things up, Try running a program that stresses the computer without accessing the drives.
If that runs fine without DPC issues, it would point to a h/w issue.
There are utilities to analyze drive issues like HDTUNE and HDSCAN, as well as SSD utilities provided by the SSD mfd like Samsung. HWMONITOR will also give you info that might be useful.
Esta resposta foi útil?
Pontuação 0
I ran into this on my HP EliteDesk 805 G8 Ryzen 3 - it was the fast startup. Disable it, restart the PC, and re-enable it. You need to go to the Control Panel, change the view to Large (or small) icons, click on Power Options, and then select Choose what the power buttons do. Once you do that, click on "Change settings that are currently unavailable", disable fast startup, restart the PC, and then reenable it. Hasn't crashed since.
One thing I found that can possibly mitigate it is a new SSD - my 805 came with a older Micron SSD (2300 series) HP stopped using and it's the one machine I have with it (my others like my EliteBook 640 G11 use newer Micron SEDs or just newer parts from Micron; my 645 G11 used a Samsung from the factory before I pulled it for a 1TB being it was 256GB stock). The SK Hynix and Samsung "PM" OEMs from HP seem to be fine, but the Micron 2300 might have firnware issues. The HPs with the WD SN OEMs are also fine and I've had yet to have the same issue.
Pontuação 0
Hi @arseni79787
Check that the SSD firmware version is V3MA003
Pontuação 0
Adicionar a sua resposta
Arseni será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 66
Ao todo: 66
