Which screw bit is required to remove charging port?
I am having trouble determining which screw bit to use to remove the charging port from a Dell Inspirion 15 3593. The screw appears to be something other than a philips head, which most of the other screws, so far, are. Any suggestions on how to solve this will be greatly appreciated. Thank you.
Esta é uma boa pergunta?
2 comentários
Turns out the screw was damaged and I had to use needle nose pliers to get it out. This was an idea that I found while browsing around the ifixit site, thank you for the inspiration. Took a while, but it worked. And thanks to all who provided an answer, the screw was a philips head, but there was not enough of the grooves for anything to grab hold of, so pliers it was.
por pogofan
@pogofan thanks for coming back to update us. Glad it all worked out for you. Repair is War on Entropy
por oldturkey03
