Ir para o conteúdo principal
The fifth-generation Volkswagen Jetta was introduced in January 2005.
How to check my transmission fluid 2007 jetta
On my 2007 jetta I have secured the car at a jack level. Now I need help locating and checking my transmission fluid
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I understand I am suppose to loosen the fill plug and if fluid "drips" out slowly then it's good. But if nothing comes out, then I need to add. Correct?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I'm not sure if you have the same transmission as my '99 bug, but there's a good chance you do. I have a document saved describing how to change the fluid, and at the end is a section on checking the fluid level. Here's the content:
Obviously most of us don't have a VAG-Com scanner, so I assume you'll just want to bring the car up to normal operating temperature by driving it (just idling it probably won't heat up the transmission fluid to normal temperature).
Other than that, you've got the basics of it down already.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Beckie Adkins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 30
Ao todo: 153
