Ir para o conteúdo principal
The Chevrolet Cruze is a compact car sold by the Chevrolet division of General Motors since 2009.
2014 turbo shut off problems
Why does my turbo not work when I turn on the ac. I've been getting a p0299pd code and erase the code and turbo works again. I've changed all the sensors, except mass air. .replaced wastegate. I've adjusted the wastegate. Checked and have not vacuum leaks. New air filter and have good oil pressure.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @elmerschields
Have you checked that there's no leaks from the intake manifold check valve?
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Elmer Schields será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 33
Ao todo: 89
