Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2983 Perguntas Ver todas
What Part Do I Change Once The iPhone 4s Gets Wet?
My phone decided to take a swim! yeah I know right? I've been letting it sit in rice for more than 24 hours it still hasn't turned back on, incase it doesn't after another 24 Hrs what can i replace to get it going again?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
4 Soluções
Solução escolhida
Here is a link to the cell phone water damage guide. Its for 3G but most of the procedures should be the same. Good luck.
Repairing iPhone Liquid Damage
Esta resposta foi útil?
Pontuação 5
Comentários:
Cool I ordered the battery and tools to open it. Gonna see what damage was done. hopefully the rice got most of the moisture.
por
Well, you should never, ever try to turn on a water damaged device.
Water itself is not damaging, but it deroutes electricity where it's not supposed to do.
So, at first, you should dismantle your device and clean it throughly with isopropylic alchol. Let the parts dry, then reassemble and evaluate.
You're surely going to need a new battery: yours surely was shorted when it got wet.
After the battery change, you could check for other signs of damage.
iPhone 4S Replacement Battery Imagem
Produto
$16,99
Pontuação 4
Comentários:
Thanks I'm gonna give it a shot!
por
Be careful. Keep every small piece handy. You may need the "iPhone Liberation Kit" to remove the pentalobes in the back.
por
The most common problem on the iphone 4S which has been exposed to water is battery failure. With the 3GS it is usually the LCD. Remember that the rice trick is only a temporary solution since moisture can still be trapped inside of the main board shielding. Read more about what to do with a wet cell phone here. As a previous poster said, turning the phone on is a bad idea as it causes electricity to flow through components that are still wet. This can easily short something out and cause more damage. Once you replace the battery pay attention to whether the phone gets hot while charging. This is a good sign that you will have problems in the future.
Pontuação 0
I replaced the battery and it power on and worked for one day then it wouldnt work again the next day is there anything more i can do
Pontuação 0
Adicionar a sua resposta
lab308joe será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Todo: 13,309
