Ir para o conteúdo principal
1ª geração do Chevrolet (Chevy) Trailblazer, baseado na plataforma GMT360.
2004 Chevy trailblazer transmission electric solenoids gone bad
Hi. I have a 2004 Chevrolet Trailblazer and the electric shifting solenoids in the transmission have burnt up. My mom was just driving my aunt to places when it wouldn't shift into 4th gear. We took it to our local mechanic and he said it's done for. But when my uncle hooked up his DTC scanner it said that the electric solenoids are shot. How do I replace the transmissions electric solenoids with new ones?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
@xanderopsp11390 we will need the exact code that you got on the scanner. What is the engine size and it s it a 4WD?
por
Its a 4WD. I'd have to ask my uncle on what code he got on his scanner.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@xanderopsp11390 this will all depend on what solenoid has failed. There are:
  • Control Solenoid
  • Shift Solenoid
  • Converter Clutch Solenoid
  • Pressure Control Solenoid
That is why we need to know the DHT code you got on the scanner.
The transmission on your Trailblazer should be a 4L60-E and here is the 4l60e Transmission Chevy Trailblazer technician guide for a rebuild. Here is the resistance chart for the solenoids
Imagem
where you have the values you can use to measure the individual solenoids. That should help you to narrow it down as well.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Xander “OPsploder” S. será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 25
Ao todo: 259
