Ir para o conteúdo principal
The HP Deskjet 2600 is a compact all-in-one inkjet printer series released by Hewlett-Packard in April 2017.
La impresora funciona pero el rodillo no funciona
La impresora se conecta a internet y funciona bien pero al darle a imprimir el rodillo suena y gira pero no coge los folios.
The printer connects to the internet and works fine, but when you press print, the roller makes a sound and spins, but it doesn't pick up the paper.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Check the paper weight first - these do not like anything heavier than 24lb premium stock, as the mechanism has a known limit on this type of printer that's not found on the other models; even the C4780, F4480 and the list of printers that end up in dumps when they break due to repair cost had the same issue as it's a generational problem with the "ultra cheap" printers that use the tricolor integrated cart. Most people who run this know they are using it, so it's unlikely, but make sure. Also, check for items like paper scraps. I would also make sure you use paper with a good texture as these printers tend to fumble with semigloss, satin and glossy stock without a little bit of help - even my TS702a needs help with heavier matte and satin stocks.
The next step would be to remove the jam door and inspect it for signs of roller wear, such as cracking or shiny spots. If you see anything like that, the printer may not be repairable - especially if the gears inside are damaged :-(. I would try and spin them freely and see - if they move super freely, the gearbox is potentially broken here. That basically makes a unit like this BER.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I've tried cleaning the rollers and following the tutorial, but it doesn't work. The paper is correct and in good condition. But it still doesn't work. The roller spins, but it seems like it doesn't exert enough force or pressure against the paper, so it doesn't go down and doesn't print.
por
HP put out a video with their official recommendations on how to fix the issue on your printer. Basically it consists of telling you to check the paper going in and take out any bent, torn or incorrect size paper, and if that doesn't work to clean the pickup rollers.
Fixing the HP DeskJet 2600 All-in-One Printer When It Does Not Pick Up Paper - HP Support - YouTube
The rollers needing cleaning is something I've run into in the past, so that's where I'd start. If that doesn't work, come on back and let us know and we'll see if we can figure out what else you can try.
English -> Spanish translation:
HP publicó un video con sus recomendaciones oficiales sobre cómo solucionar el problema de tu impresora. Básicamente, consiste en revisar el papel que entra y retirar cualquier papel doblado, roto o de tamaño incorrecto. Si esto no funciona, limpiar los rodillos de recogida.
Reparación de la impresora multifunción HP DeskJet 2600 cuando no recoge papel - Soporte HP - YouTube
Ya me he encontrado con que los rodillos necesitan limpieza, así que empezaría por ahí. Si eso no funciona, vuelve y avísanos para ver si podemos intentar algo más.
Pontuação 1
1 comentário:
por
@gabri53490 it is possible that this is an issue with either the paper-delivery sensor or issues with the paper pick up rollers. Could be that those are just dirty or just wore out. To clean those, check something like this video Not the same model but the same series and should work for your model too. Next, try what HP suggest on here In the meantime we'll see if our printer Guru @nick has a solution or you.
Translation
@gabri53490, es posible que se trate de un problema con el sensor de suministro de papel o con los rodillos de recogida de papel. Puede que simplemente estén sucios o desgastados. Para limpiarlos, consulta este vídeo. No es el mismo modelo, pero es de la misma serie y debería servir para tu modelo. A continuación, prueba lo que sugiere HP aquí. Mientras tanto, veremos si nuestro experto en impresoras @nick ti
Pontuação 1
Adicionar a sua resposta
gabri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 46
Ao todo: 330
