Why can't my MacBook Pro update!
i earsed a lot of my data but it still says that i can't update because my memory is full !!!!!!! what should i do!!
help!!
Esta é uma boa pergunta?
help!!
You could purchase a bigger hard drive and install it which would free up lots of space. I had this problem on a 250 GB hard drive so I installed a 1 TB hard drive which gave me plenty of space and used Carbon Copy Cloner to transfer data over. If you give me the last 3 digits of your serial number then I can point you in the right direction.
Hope this Helps.
Esta resposta foi útil?
last three digits: RJC
THANKS YOU HELPED A LOT!!! AND YOU ARE RIGHT, i'll purchase a harddrive for extra space!!
What size hard drive do you have in the Mac at this time? You can see by hitting about this mac -> more info -> storage tab. When you tell me the hard drive capacity and I can give you several hard drive options and the installation guide.
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 616
1 comentário
ok here is the last three digits RJC
por iApple
