Why is my Tv hdmi dosent work on ps4
Ive bought this android tv toshiba 2 years ago and i wanted now to play ps4on it ,the problem is it shows black screen when i plug the hdmi cable i only hear the sound ,but the ps4 device works on other tvs though ihad this LG tv and its not even smart and it works very well others tv also,but this tv doesn’t,ive tried safe mood and changing the cable many times i also reset the settings if the tv but there’s no response, although the tv works on laptop when i plug HDMI cable very well so what seems to be the problem.
Esta é uma boa pergunta?
Hi @albertenisten
Please confirm the full model number of your Toshiba TV?
por jayeff
Model :43L5965EA
LED
por Albert enisten
To help identify why the PS4 only shows a black screen (with sound) when connected via HDMI to your Toshiba TV 40PB200, could you clarify a few things:
1. Have you tried changing the PS4 video output resolution manually (e.g., to 720p or 1080i) before plugging it into the Toshiba TV?
2. Is HDMI-CEC (Consumer Electronics Control) or any HDMI settings enabled or disabled on the Toshiba TV?
3. Have you tested all available HDMI ports on the TV?
4. Does the Toshiba TV show any signal message (like "no signal" or "unsupported format") when the PS4 is connected?
This info can help pinpoint whether the issue is compatibility, signal format, or handshake-related.
por Markus Norstrøm
Thank you @Markus for the reply
Replying to your questions :
1:ive tried to change the ps4 many times
2:HDMI is not disabled on my tv as it does work on the laptop and ive already checked the settings
3:ive tried brand new HDMI ports on the tv
4:yes it some times shows no signal and sometimes it shows only black screen with sound
por Albert enisten
One last question.
Which PS4 are you using? Fat, slim or pro? It should give a model specification on the PS4 somewhere
por Markus Norstrøm
Exibir mais 2 comentários
