Ir para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Perguntas Visualizar todos
Screen upgrade to iPad 3 retina?
Would it be possible to replace an iPad 2 display with a retina display for the iPad 3?.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
In short, no. The iPad 3 has a completely different connector on the logic board and it is located in a different place. There are also firmware incompatibilities that wouldn't allow you to do it. The iPad 2 isn't meant to drive such a high resolution.
Hope this helps.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Darrin Jens será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 2,132
