Ir para o conteúdo principal
Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
Icemaker is slow to make ice. We seldom hear it drop and run out a lot
Our Icemaker is slow to make ice. We can hear when it drops, and it drops seldom. We often run out of ice and wind up having to buy a bag to add to the bin. Is there some sort of sensor that can be adjusted?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thank you for your help.
por
Adicionar um comentário
1 resposta
Solução escolhida
Check to make sure freezer temp is set properly - I use -5*F
Check filter is not clogged - Change every 6 months
Check water supply hose is not kinked - turn off water, disconnect from fridge, put end in bucket, turn on water. It should jet out of the hose unless it is damaged.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Michael Moxley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 112
