Ir para o conteúdo principal
Repair guides and support for vacuums by Dyson, including upright, canister, and handheld vacuums.
Busted Hose Need to Know How To Get Replacement
As you can see in the pictures my vacuum has a busted hose. It is at the bottom of the machine beside the ball filter. I ordered the part from Dyson that I thought was it but it wasn't. I spoke with Dyson support and they didn't know which part I needed even after sending them the photos. Can someone please tell me what part I need and how to get it? I do NOT want to go to a service center that is 2 hours away.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @mandywesson
What is the model name and number of your Dyson vacuum cleaner?
por
Hi @jayeff ... it is Dyson Ball™ Multi Floor 2 upright vacuum parts ... UP19 .... TJ4-US-KEC5519A
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @mandywesson
I think what you need is part number 924796-02. (supplier examples only)
Search online for the part number only, to find other suppliers that may suit you better.
Not totally sure if it's applicable to your particular model, but here's a video that shows how to replace it that may help.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi Jayeff ... thank you for that information ... I already ordered that part and even tho they look very similar, unfortunately it wasn't the correct part. Do you any other suggestions about how I can get the correct part?
por
@mandywesson
Is there any information stamped anywhere on the hose at all?
I just went on the fact that it was a "UP19" model and most suppliers state that this part is (example only).
por
Adicionar a sua resposta
Mandy Wesson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 37
Ao todo: 139
