Ir para o conteúdo principal
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Perguntas Visualizar todos
PowerBook wont start again
hi there
ac connector (65 watts! ) the dc plug ( goes into book) broke while i was on trip.
book was left on for 2 days.
finally the already weak battery went dead.
book indicator lights kept blinking for 2 more days but book didnt start up anymore.
now i got a new (65w) adapter, book wont start anmyore. no sond, no fan, not any noise of responde. no indicaterlights are blinking and it doesnt charge battery either.
is there an internal batterypack as it was with the old G4 titanim that could run dead?
(guess batterypack now is completly dead wich i supposed did happen after complete drain)
(PMU restart failed also with new ac connected.
any suggstion?
PowerBook G4 17
PowerBook 5,1 1 GHz
Ram 1 GB
Bus 167 MHz
Boot-ROM-Version 4.6.2f1
Esta é uma boa pergunta?
Pontuação -1
2 comentários
thanks for the replies.
got a brand new battery (fully charged) for the book, still not starting. did also the remove of battery and power press start button the 5 sec etc. no reaction.
any new hints?
por
Did you replace the PRAM battery?
por
Adicionar um comentário
2 respostas
Solução escolhida
After getting about a 20% charge as Owen mentioned if it still won't start, remove the battery and AC adapter then press and hold the power button for 5 seconds. Replace the battery and power supply and give it a try. Yes, this machine does have a PRAM battery. If you keep losing the date and time, you'll need to replace it. Here's how: PowerBook G4 Aluminum 17" 1-1.67 GHz PRAM Battery & USB Board Replacement
Esta resposta foi útil?
Pontuação 3
These powerbook models, to my knowledge, must have some charge left in the battery to start. If I completely drain my PowerBook G4 I have to put another somewhat charged battery in it before it can start. Once it is started you can keep it pugged in and change the batteries. I would ask if a friend has a battery you could borrow or maybe a coworker.
Hope this helps.
Pontuação 1
Adicionar a sua resposta
Ren será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 538
