Ir para o conteúdo principal
iRobot Roomba 5xx Series Battery Replacement
I want to replace the battery pack on an iRobot Roomba 500 series. How do I gain access to the battery pack already installed in the Roomba? I have seen photos of a battery pack purchased from batteryspace.com intended for the Roomba, but not photos showing how to access the battery compartment itself. Thanks, Bob Cochran
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
I've got the URL for the manual for the Roomba for you. Scan down and you will find info on removing and replacing the battery. Ralph
http://www.irobot.com/uk/home_robots_faq...
Esta resposta foi útil?
Pontuação 2
Hi, before you go and buy a replacement battery, you might want to try to reset the Roomba first. The Roomba may be set in a state where it will only charge to a certain amount. Just follow the instructions indicated here to reset your Roomba.
http://www.eesolutions.ca/roomba_battery...
Pontuação 2
Adicionar a sua resposta
cochranb será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 8,140
