Ir para o conteúdo principal
The Intellivision is a video game console released by Mattel in 1979.
13 Perguntas Visualizar todos
Help with my Intellivision! #2
Well, the old question was getting cluttered, so I started a new one. Now, TP4, is not getting power. (That's capacitor #3 on the power supply board.)
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
hello, check your transformer and make sure that you have the proper output. Also, make sure that the diodes in the rectifier circuit are all functioning. If all that is working, replace the capacitor and recheck.
Esta resposta foi útil?
Pontuação 2
A couple things to always do if you have a power issue. First reflow the solder joints on the faulty capacitor. The caps on the power supply are heavy and eventually will crack the solder joints. Second is to take the power switch apart and clean it and reapply dialectic grease.
Pontuação 0
Adicionar a sua resposta
thelectronicnub será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 2,596
