Ir para o conteúdo principal
The Toshiba Satellite is a laptop released in 2009.
Why can't I log in?
I can't enter the the windows tab , it keeps saying reset and when I reset it it still gives me the same screen.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This usually happens when system files are damaged, the hard drive is failing or a previous reset or update failed. So here is a solution step by step:
# Access advanced Startup options, than go to Starup Repair, that might automatically fix the issue. If that does not work, oper Command Prompt and type: chkdsk c: /f /r This will check for disk errors and attemp to fix them. It can take a while. Hope this will help.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bijay Sookraj ,9C será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 67
