Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
MacBook Pro doesn´t turn on but charges the battery
Hello
i have a Macbook Pro Mid 2009 13" and the problem is that it wont turn on. When i press the Power button nothing happens, its dead. But the battery charges and the LED on the left side shows the battery status.
Can you please help me?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Have you spilled anything on it?
por
No i didnt spill anything on it.
por
Adicionar um comentário
4 respostas
Solução escolhida
Your power button could be non functional. You could remove the bottom panel, disconnect the top case ribbon cable from the logic board then trigger the two power pads on the logic board to power up the machine. If the machine starts up then you know your top case is in trouble.
Esta resposta foi útil?
Pontuação 3
2 comentários:
I'm assuming by top case ribbon, you mean the one on the top right after opening the bottom panel, with battery close to you. But where are the 2 per pads on the logic board to power up the machine?
por
Question, does this fix the button or merely turn on the macbook ?
por
this might help
http://support.apple.com/kb/TS1367
Pontuação 2
3 comentários:
Tried to reset but it didn't work. The light of the power cable didn't change.
What else can i try?
por
Move your Moniter in different angles while pressing the power button
por
It doesn't help because nothing happens when I press the power button, no fan noise, nothing
por
try one of these solutions
http://youtu.be/Igspc4eymuQ
Pontuação 0
I have a problem that my mac doesnt turn on and the battery shows the signe that ok and it charged normaly but when i press to turn on he make like when noise and exactly iheart it coming from the hitachi how you could help me please?
Pontuação 0
Adicionar a sua resposta
Fuad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 38,765
