Ir para o conteúdo principal
O Cruzer Blade é um pendrive USB 2.0 lançado pela SanDisk.
Where to solder on for sandisk thumb drive to recover data
Imagem
I am trying to recovered data from infinitive usb 2.0 32 gb broken thumb drive. Can someone tell me if I can solder on to the pcb the 6 holes or pads, and which one is data, ground vcc etc.
Thank you in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I don't think the six holes will offer what you want.
If you look at the USB plug attachment part of the PCB (left side) where it's broken you can trace the lines to the chip which are not wired to the holes as there is no via's to jump to the other side (likely a two layer board). I would use a meter to check continuity where the solder joints are on the chip and the severed lines where the board snapped to find the needed lines.
Do you know which version of USB this thumb drive offered? As that gets into how many lines need to be connected. Here's a good reference USB Pinout, Wiring and How It Works
Then repeating the same task on the broken plug piece you should be able to identify which line goes to which pin of the plug. Then using an old USB cable of the same rev of USB soldering on the tails to the board as needed.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you, I was able to do the tracing and get leads on this but unfortunately the nand maybe cracked, saw that under the microscope later. I appreciate the help.
por
Adicionar a sua resposta
sergeyvjr será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 250
