Ir para o conteúdo principal
ASUS TUF Gaming Laptop - FX505D-DBQ234T com i5-8750H e Nvidia GeForce GTX. MFD-2019-05.
Why is my wifi adapter not working?
In device manager the wifi adapter is showing (code 10) error.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @tarunraikwar
Is the latest Realtek Wireless LAN Driver Version 2024.0.8.107 2019/05/28 installed?
Also check in BIOS - Security (or Advanced) for any settings relating to WiFi e.g. I/O interface or Onboard Configuration to check if the WiFi has been disabled.
Esta resposta foi útil?
Pontuação 1
I have been worked with this issue. The simplest and easiest solution is if there are no software issue or driver issue.
If you go to service centre they will change entire wifi bluetooth module and they will cost you decent amount of money without any reason.
  1. open the back panel (remember that which screw is where)
  2. you'll find wifi + bluetooth module under the SSD.
# plug it out clean the yellow part with eraser or recommended cleaning solution. (I have done it with eraser)
  1. Plug it in.
  2. Tight all the screws back.
  3. Problem solved.
Pontuação 0
Adicionar a sua resposta
Tarun Raikwar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Ao todo: 196
