Ir para o conteúdo principal
Informações e guias de reparo para consertar desumidificadores, um eletrodoméstico que remove a umidade do ar da sua casa.
Help finding a compatible capacitor for GE Hisense DH70KP1WG
Need a new capacitor, and cannot find CBB65 50uF +5% 250VAC anywhere. I can find with a different uF or +6% or higher VAC. Specifically, the closest I have found is 50 uF ±5% 50 MFD 370/450 V CBB65. Should this work, or not?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @cz12337240
It is OK to use a capacitor having the same capacitance value and a higher voltage rating than the original.
Never use a capacitor with the same capacitance and a lower voltage rating than the original as most likely it will damage the capacitor and possibly other components as well.
Esta resposta foi útil?
Pontuação 2
COCAPCO CBB65 250VAC 50uF Run Capacitor 50MFD 50 uF MFD 250V AC SH B.P2/S2 50x76mm 40/70/21 UL Listed: Amazon.com: Industrial & Scientific
I'm seeing several on Amazon that meet your specifications. The only other consideration would be the package size; you may have to measure the height and diameter to ensure it fits, but if there's room for it, this one would work. A general search for "CBB65 50uF +5% 250VAC" shows me several results.
Pontuação 1
Adicionar a sua resposta
CZ123 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 22
Ao todo: 263
