Ir para o conteúdo principal
Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
Frigidaire double door model # ffss2315tp4
We have a Frigidaire double door fridge, the codes are 0 on freezer & f on fridge. When plugging in 3 beeps happen, lights are on and ice maker makes noise but it isn’t freezing or cooling. No fans are cutting in or any noise. Any ideas?
Update (07/02/25)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @elisha42099
Did you leave it unplugged for approx. 2-3 minutes before reconnecting the power to the refrigerator?
This is the usual way to reset to control board in your model.
If you didn't, try it and check what happens. If you did and it's still not working, here's the service data sheet that may help.
Activate the Service mode and perform Test #9, sub test A (Error History Log) as described, to check if any error codes have been logged. If there are any, the error code meaning is shown in the Test 9 Error codes table.
If there is an error code and you find the cause and it's a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown with it. Search online for the part number only, to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky you'll find videos that show how to remove/replace the part.
Note: FF = refrigerator compartment, FZ = Freezer compartment
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Elisha será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 33
Ao todo: 228
