Ir para o conteúdo principal
Lançado em 26 de outubro de 2018. Modelos A1984, A2105, A2106, A2108. Disponível como GSM ou CDMA / eSIM, nano-SIM ou SIM dual / 64, 128 ou 256 GB / Preto, Branco, Azul, Amarelo, Coral ou Vermelho. (Pronuncia-se "iPhone 10 R.")
What is this mystery metal piece in iPhone XR?
I am attempting to replace my iPhone RX screen. Unfortunately the first replacement screen I received was damaged so I had to wait for a second.
I notice that in the waiting time for the new screen to arrive, that a tiny piece of metal that seems to float between the lens gubbins and the new screen has disappeared! See the two screen shots from the how to video I am using. Does anyone know what this piece does? And more importantly, will the phone/camera work without it? Can a replacement be purchased?
Any help will be gratefully received. Thanks in advance.
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It's a bracket that holds the sensor required for Face ID in place to the frame of the LCD.
Esta resposta foi útil?
Pontuação 1
2 comentários:
So I won't be able to use Face ID but otherwise the phone should work?
por
I know this is a very late response. As long as the sensor and cables are not torn, the bracket isn't required.
por
Adicionar a sua resposta
Ian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 323
