ice maker rear is freezing up and causing ice on the back wall fridge
the icemaker rear right is freezing up within the refrigerator
Esta é uma boa pergunta?
Hi @lynnbeasley
Here's the service data sheet for the refrigerator model.
Perform the Fresh Food Ice Maker Diagnostic Mode tests as described and check if all the tests show if everything tests OK or not.
If there is a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown with it. Search online for the part number only to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky there are videos that show how to remove/replace the part.
Also make sure that the ice maker fill time is set to minimum as shown in the Ice Maker Fill Time Adjustment procedure
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 101
2 comentários
Hi @lynnbeasley
What is the make and model number of the refrigerator?
por jayeff
Frigidaire model fghb2868tf4
por Lynn B. Easley
