Ir para o conteúdo principal
Lançado oficialmente em 10 de novembro de 2023. Este smartphone econômico possui uma grande tela de 6,74 polegadas com taxa de atualização de 90 Hz.
How to repair a cellphone lcd screen
I At that time my cellphone fell to the floor and the cellphone didn't use tempered glass so it cracked. How do I repair the LCD glass without having to replace the LCD?
Esta é uma boa pergunta?
Pontuação 7
Adicionar um comentário
2 respostas
Pergunta mais útil
Modern phones bond the LCD and digitizer to the front glass. Separating them generally requires using a vacuum table to hold down the display while you use a fine wire to separate the glass. Following that you'll need to clean the old adhesive completely then add a layer of optically clear adhesive (OCA) between the new glass and the LCD. Put the assembly into a vacuum chamber to remove the air bubbles, then into a UV chamber to cure the OCA.
Kind of a lot of trouble and adhesive, assuming you can even find the front glass; that may or may not be available for you particular phone. I would suggest just replacing the complete screen assembly; a quick search online shows some inexpensive screens selling for anywhere from $15 to $30 USD. Here are a couple of the cheaper examples I ran across with just a cursory search.
6.74" High Quality For Xiaomi Redmi 13C LCD Display Touch Screen Digitizer For Redmi 13C Display LCD 23100RN82L Replacement Part - AliExpress 509
Wholesale For Xiaomi Redmi 13C 4G / 5G / Redmi 13R 5G / Poco C65 4G Grade B LCD Screen and Digitizer Assembly Part (without Logo) Custom Available - TVCMALL
I wasn't able to locate a written guide like iFixit provides, but there are YouTube videos available, such as this one.
REDMI 13c LCD Replacement - YouTube
Esta resposta foi útil?
Pontuação 2
My phone is working in background and the screen doesn't work
Pontuação 0
1 comentário:
When you say the screen doesn't work, are you saying you can't see anything on it, or it doesn't respond to touch?
Either way, the fix is the same; replace the screen as I outlined in my answer to the original question.
por
Adicionar a sua resposta
dawaaa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 109
Ao todo: 1,345
