Ir para o conteúdo principal
O Ford Freestyle foi um veículo utilitário crossover que antecedeu o Taurus X
2007 Ford freestyle stops and restarts while driving
Why does my car stop and then restart and then it smells like it’s overheating and then I have to pull over and turn my motor back on and sounds like out of gas
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Susie, have you had the engine computer scanned for trouble codes? That's going to be the first step in diagnosing the problem; anything serious enough that the car stops running will almost certainly generate one or more trouble codes that can point you in the direction of the problem.
Here in the US most auto parts stores will hook up their OBD scanner for free and give you a list of any codes they find. Or if you have a friend or relative with a code reader, you could ask them to scan your car for codes. Worst case a mechanic will do that for you, but of course they'll charge you for it.
Once you have the code or codes, come on back and edit your question to add that information and we'll have a much better chance of being able to help.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Susie Ames será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 134
