My hard disk drive keeps pepping but it doesn't show on my computer
my hard disk drive keeps pepping but it doesn't show on my computer
Esta é uma boa pergunta?
Yeah, that can be really annoying. If your hard drive makes a sound but doesn’t show up on your computer, try these simple things:
If it still doesn’t show, don’t worry—sometimes it’s just a software issue. You can try data recovery tools to scan the drive and get your files back. Just be sure not to format the drive unless you’ve recovered what you need!
Esta resposta foi útil?
i have same issue, even bios and Disk Management (on Windows) not showing the hdd. and it has sound like clang or tick
How did you fix it ?
If the drive isn't showing up at all, recovery software like Remo probably won't help until the hardware issue is fixed. You can still try recovery tools from Recuva or Remo Software if the drive gets detected, but if it keeps beeping, stop using it to avoid making the problem worse.
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 89
Ao todo: 1,429
My harddisk did not work & not showing in my computer 1tb plz recovery of my harddisk suggest person so he fix it my problem
por Paresh Bavaliya
