Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
Why are my speakers not working?
I was playing on my Nintendo switch the other day, playing Pokemon Unite, with the volume all the way up, when my speakers started to have bad sound quality then just stopped playing sound. I cannot tell if there is any buzzing in the speakers when trying to play audio, but in this case what do I need to do to fix this? Thanks! (P.S. headphones, wired or Bluetooth, and sound when the switch is docked that is coming from the TV still works.)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
I would say the Audio IC, but this is probably not it, because you still have sound wired, docked and also with the headphones.
I would try to replace the speakers actually. As you have stated "Speakers started to have bad sound quality". I would just replace them and see how it goes. They are easy to replace!
Guide: Nintendo Switch Speaker Replacement - iFixit Repair Guide
Let me know if you need parts or something else!
Esta resposta foi útil?
Pontuação 3
4 comentários:
Should I replace one or both speakers when testing?
por
Both in this case! Let’s try that :)
por
Well, at least 6 months later, I finally got around to replacing them and I put the new ones in and now I have sound again! Thank you koppie007 for your help and guidance. I now have 2 new speakers in my system and they worked perfectly. I hope you have a good day and may your repairs always go well. (sorry for the laziness on my part.)
por
Hi @jfix8745 I'm glad that you've got it fixed :)!!
My pleasure, happy to help! And no problem, when you are busy then it is, what it is :)!
I hope you have a good day as well! Thank you :)!
por
Adicionar a sua resposta
JFix será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 34
Ao todo: 183
