Ir para o conteúdo principal
Repair guides and troubleshooting information for hair dryers.
My Rowenta Hair Dryer 2000kw does not blow hot air anymore!
Hi everyone,
I have a rowenta hair dryer which has stopped heating up right away. It blows cold air only. It has 2 speed buttons and 1 cold air (not needed anymore!!!!) one. Can u guys help me? TXXXXXX!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
The heating coil probably has a break in it (most common cause for failure). The problem is getting a good replacement part. It does have a one year warranty: http://www.rowentausa.com/rowenta/frame....
Esta resposta foi útil?
Pontuação 2
well I recommend you to buy a new one, normally when it starts to fail it's better to get a better one. If you decide to do that, I suggest the one I use, it's the Karmin G3 Salon Pro Hair Dryer which dries the hair really fast and keeps my hair smooth, shiny, frizz less and healthy. :D If you are interested you can check it out at safrons. com :D
Good luck. :)
Pontuação 0
well im just gessing but when you turn on the hair dryer check and see if the heating elememts inside are heating up if not then i would replace the heater coil if that dident work then i would do as Brownmoniq says and just buy a new one because if its not the coil then is has something to do with the control board
Pontuação 0
Adicionar a sua resposta
Laurie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 5,718
