Ir para o conteúdo principal
The Canon EOS Rebel T7 is a 24.0MP DSLR camera released in 2018. Also known as the EOS 2000D, the EOS 1500D and the EOS Kiss X90.
The flash is working but not the thing that flips up of the flash
the place of the flash, it normally pops up. But I only hear a click and it does not pop up
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This means your flash is stuck into place. Usually you will hear two or three clicking sounds and then see an error message on the screen. When activating the flash, try to lift it up. If you can, then the spring holding the flash in place is stuck. If you can't lift the flash, try to pry it open with a pry tool or another flat tool.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Margaret Foster será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 30
Ao todo: 207
