Ir para o conteúdo principal
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Perguntas Visualizar todos
Airport,bluetooth won't work after repair.
Hi
I have just installed a ekstra harddrive instead off the optical drive.
I used the guide to optical drive.
All went fine and the new drive works fine, but now are airport, bluetooth, isight and light sensors not available more.
I have checked the camera cable 5 times but i won't work.
I have also reset PRAM.
What should i do??
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
You may have inadvertently damaged the ribbon cable or the pins leading to the AirPort / Bluetooth card. You should buy another ribbon cable that looks like this -->
Best,
-- Morris
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mail será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 598
