Why is battery and handbrake light comes on intermittently?Goes on off
Lights up intermittently, on and off at times. Replaced with a brand new alternator and Din66 Battery but still same
Esta é uma boa pergunta?
Does the "brake" light on the dash turn on when the ignition is set to On and the hand brake is applied?
Does the "brake" light on the dash turn on when the ignition is set to On and the parking brake is not applied? If so check the brake fluid level is OK.
The "brake" light is used for both the hand brake and the foot brake systems.
Esta resposta foi útil?
Both of those lights coming on would not be an indication of an alternator or battery problem.
It may be a loose or shorted wiring issue or an ECU issue.
More observations of anomalies might help diagnose it.
Is anything else happening when the lights come on?
Do they come on together or individually?
Is there a specific time they come on, or is it totally random?
Is your handbrake totally disengaged?
Did you check the handbrake switch and wiring?
It just comes on randomly, both lights at the same timing. Recently replaced with a brand new alternator and Din66 Battery. Handbrake light works perfectly, no doubt with this.
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 113
