echo dot 5th gen isn't going into set up mode
So I have a echo dot 5th gen the problem with it is that when you try to set it up it doesn't go in set up mode or if you try reseting it I'm no sure if its even reseting either how to can I fix that problem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
