Ir para o conteúdo principal
Water fixtures and their piping, as well as the myriad of components that keep them flowing.
What Is the pH of Drain Cleaner?
Hey everyone, I have a question about drain cleaners. What is their pH level? Are they acidic or alkaline?
Also, how does the pH affect their effectiveness in unclogging drains? Which type is safer and more effective for home use?
Looking forward to your answers. Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hey there!
Great question! Drain cleaners can be acidic (pH 1-3) or alkaline (pH 12-14). Acidic cleaners are great for tough clogs but can be harsh on pipes. Alkaline cleaners, on the other hand, are generally safer for your plumbing and work by breaking down grease and fats.
While both types can be effective, alkaline cleaners are usually safer for your pipes. Just be sure to follow the instructions carefully!
If you want to learn more about different drain cleaners and their safety, check out this blog for more tips: [ How Much pH Does Drain Cleaner Have? ******]
Esta resposta foi útil?
Pontuação 1
Related Parts and Tools
Pergunta mais útil
Hi @johnbruce1
Most drain cleaners are on the high side of the pH range usually 11.0+ (up to 14 which is max range for pH), which means that they are alkaline.
They are effective at cleaning drains because they dissolve the greases etc, but they can also damage plastic and older metal pipes so they need to be used cautiously.
They are not effective if the drains are being clogged by tree roots etc.
The higher the pH level the stronger the cleaning effect is but also perhaps the damage it can cause.
Looking at a few commercially available products they don't specify the pH level on the label so you wouldn't know what it is.
Best option is to watch what is put down the drain and try to minimize clogs from occurring, e.g. use sink strainers, don't pour cooking fats down the drain- allow to solidify and then scrape off pots etc and dispose in garbage bin etc. Also follow the 3 P rule for toilets i.e. pee, poo and toilet paper only to be flushed, nothing else.
Pontuação 5
1 comentário:
Most are caustic and chlorine based which breaks down greases and proteins.
If the water is flowing you likely want to use a foaming type so the full pipe wall is covered, not the bottom alone.as the longer it sits on the clog area the better.
por
Adicionar a sua resposta
John Bruce será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 28
Ao todo: 88
