Ir para o conteúdo principal
Repair and disassembly information for Logitech's MX Keys wireless keyboard. Identifiable by model number YR0073.
Unable to change Capitals to small on my MX Keyboard. Caps lock KEY
I have been trying to contact you many times, I have asked machine various times. I purchased my MX Keyboard Direct from you. The “caps lock” key does not illuminate. You may say my Warranty has run out, but it was live when I started to try and contact you, over the last year. Your question pages must be full of my question. But no one ever answered. So with this new page I will try again. “HOW CAN I CHANGE THE caps lock KEY TO ILLUMINATE AND CHANGE FROM CAPITAL TO SMALL PRINTING? Thank you. Brian
allt4587@gmail.com
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
The key does not work at all I cannot change the letters at all and the base of the key never shows the illumination.
How can I get the key light up etc. Brian
por
The base of the “caps lock” key no longer illuminates, and I cannot change Capital then back to small word if I press the caps lock key? Brian
por
Adicionar um comentário
1 resposta
If the cap lock LED is not illuminated, then caps shouldn't be on. So, everything should be lower case.
If cap lock doesn't illuminate when key is pressed, then key may be disabled.
This article may help.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Yes but how can I illuminate the rear of the key and change the size of the letters from small to Capitals?
por
Did you check the article?
por
Adicionar a sua resposta
Brian Allt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 277
