iPhone 4 and 4s battery the same?
Can I use an iPhone 4 battery in an iPhone 4s ?
Thanks!
Esta é uma boa pergunta?
Cancelar
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
Thanks!
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa LojaUnfortunately the simple answer is no. The iPhones 4's battery has a different voltage and the connector is slightly different. If you need a new battery you can get one from here,
that will work no problem in your phone.
Hope this helps.
Comentários:
voltage is the same at 3.7. 4s batt has tiny more watt hrs. make it fit by modify connector tab only.
por Charles Griffith
por Saeed
The voltage is the same. They are both 3.7 volt batteries. However the 4s battery has a very slightly higher capacity.
por an person
Batteries are different physical size as well. The 4 is bigger than the 4s. Normally the 4s will fit in the 4, but not vice-versa.
Comentários:
Very helpful ta very much. Ytnir.
por leslie dixon
if i need a battery for an iphone 4, will the 4s battery work?
I think the 4S fits in the 4, yes, but this is a terribly late answer to your question :-)
por davidbaird
Rep: 1
Comentários:
por an person
Últimas 24 horas: 16
Últimos 7 dias: 85
Últimos 30 dias: 416
Todo: 139,268
can i use an i phone 4s battery on an iphone 4
por sudha
Can I use a 4g battery in a 4 s
por John
can i use iphone 4s battery for iphone 4
por Rekha Gore
Yes you can use it..but fix the connecter in opposite side...I am using...
por nilimesh15ganapati
