Ir para o conteúdo principal
O Windows 11 apresenta uma interface de usuário totalmente nova, incluindo uma nova barra de tarefas, novos ícones centralizados, transparência de janelas, cantos arredondados e uma Microsoft Store atualizada.
Things I should do before I plug in my battery for windows 11?
i am finishing up a repair on my laptop and was wondering if I need to do anything before i plug in the battery. It runs windows 11, so I don’t known if i have to do anything special when it boots.
Thank you for the help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @natetheegreat
Best thing to do first, after installing the battery is to make sure that it is fully charged before starting the laptop.
Once it has charged then you should be able to start the laptop.
After the laptop has booted into Win11 and settled down, go to Device Manager > Battery and uninstall the Microsoft ACPI Control Method battery drivers.
Once they have been uninstalled, close any open windows and then restart the laptop in the normal manner.
During the following startup, Windows will reinstall the battery drivers.
Doing this will forestall any problems with the OS possibly not recognizing the battery so that it will work correctly etc.
You can create a battery report to view the status and condition of the battery, if you want to.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nate será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 253
