Touchscreen's left edge does not work
As the title suggests, left edge doesn't work top to bottom. For example you can't type q while using the keyboard.
I took the thing apart and found out that there were some corrosion-y stuff on the display flex cable thing right under a small black sticker. I peeled it off, revealing 4 solder pads and cleaned out the gunk - still the same, no improvement. At least it didn't go out completely!
Can I salvage this display in any way? I really want to keep this device original.
Edit: Left edge DOES work sometimes but only for a shortwhile. The screen will go unresponsive for a second and then the fault area won't respond to touch again.
EDIT: I should add that I'm the second owner of this device and thus I don't know the precise history of it. IOS shows no service history but it might have been dropped (scuff marks on case.)
EDIT: Pictures of what I found:
I tried to clean the pads and the result:
Last image is how it's supposed to look like according to iFixit.
Esta é uma boa pergunta?
The corrosion on the display flex cable area suggests possible liquid damage or oxidation, which might be affecting the touch signals.
por Stuey
