Ir para o conteúdo principal
Similar to the Dell OptiPlex 7010 in specs.
Why is my Dell computer comes ON but yet no display on the monitor
My Dell computer switches ON well but no display why
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@mbockmoses have you tried a different monitor? Have you tried to connect the monitor to a different computer to see if it works? Do you use a discrete video card or are you using the integrated one? Did this ever work for you and did it just quit working or did anything happen to your computer? What have you checked?
por
Adicionar um comentário
1 resposta
You may not have properly connected the monitor cables to your case, or the monitor wire is damaged, or the ports at the beginning and end of the cable are damaged, or the connection socket of the case or monitor itself is damaged, so it must be healthy. Make sure these
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mbock Moses será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 168
