Ir para o conteúdo principal
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
How do I reset my Quite Partner II Dishwasher
Mine is model DU1055XTVS0. It just ran and now nothing lights up. Hard wired. How can I reset it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @jimthomas71983
Have you checked that the house power box fuse (or circuit breaker) that the dishwasher is connected to is OK and not blown (or tripped)?
If the fuse is blown (or breaker tripped) then there must be a reason for this to happen and this would have to be further checked as to why. Perhaps replace the fuse (or reset the breaker) and run the dishwasher and see how far it progresses through a wash cycle before it fails again
If the fuse/circuit breaker is OK and there's no indication of power on the dishwasher, here's the tech sheet that may help.
Go to the Troubleshooting Guide on p.2 (left hand side) and view the checks for a no power situation.
If for example the thermal fuse in the dishwasher has blown then again there's a reason for this which will have to be investigated.
If you find the problem and it is a faulty part that needs to be replaced, here's the parts list that is useful. Locate the wanted part in the list and note the manufacturer's part number that is listed with it. Search online for the part number only to find suppliers that suit you best.
Sometimes there may be videos on YouTube that show how to remove/replace the part. Search on YouTube for (insert wanted part number) replacement.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jim Thomas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 106
