How can I replace my rechargeable batteries in my hearing aids?
Esta é uma boa pergunta?
If it is less than 3 years old, it should be covered under warranty. If it is not a new Oticon Intent - and it isn't because it doesn't look like mine - only Oticon can change it. Most others can be changed by your audiologist. It requires the right battery and a very tiny pin tool to push the pins out that hold it together. I have no idea where either might be obtained.
Esta resposta foi útil?
If your hearing aids are made like the ones in the picture it will be alot more trouble to replace them yourself. Take them back to where you got them and ask.
I have added a picture of the hearing aid that I posted my question about.
Most modern rechargeable hearing aids have built-in lithium-ion batteries that are not designed for user replacement. If the battery is no longer holding a charge, it is safer to have the manufacturer or a qualified hearing-aid technician replace it rather than opening the device, which can damage the electronics or affect its water resistance. Check the hearing-aid model before ordering any replacement battery.
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 93
Ao todo: 1,683
6 comentários
GGeorge, there are way too many hearing aids on the market for us to be able to answer your question without knowing more. Specifically what we need is the manufacturer and model number of your hearing aids; otherwise we can't even guess as to what to tell you.
At a minimum, adding photos of your hearing aids might help, but the make and model would be far better.
Adicionar imagens a uma pergunta já existente
por Jerry Wheeler Compartilhar
My hearing aids are Phonak Audeo M70-RT.
Behind the ear type.
por GGeorge Compartilhar
I have been looking at this as a UK first time user of HA. My audiologist assure me this is feasible and the BTE (behind the ear) models follow a similar a patten. At over £4,000 a pair I do not look forward to dumping them every 18 months when the batteries fail. Starkey and Oticon are almost identical except the label and the charger shape.
por Jigsaw Electrical Compartilhar
Called Oticon technical support. Their answer is, return them via the audiologist for battery replacement by the manufacturer; cost unknown.
I sent mine to an outfit called HearSource.com. It was $249 per aid, and I had them back in four days. Nice folks.
por Charles McElwee Compartilhar
Exibir mais 1 comentário
