My PS Vita is not powering on
The PS light turns orange when charging and stops charging after a while (which I'm 99% sure means it's fully charged) and I also tried changing the battery. Nothing so far work, as when I click/hold the power button, there is no sound, no light on screen and no blue light on the PS button. Anyone got ideas?
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Hi! Probably motherboard related :(. Is the PS Vita modded? What happens if you try to turn on the Vita while it’s charging?
por
Shouldn't be modded, recieved from my uncle which has a ps vita that is not modded so I doubt he'd have modded that one. Nothing happens if I try to turn it on when charging, but doing the combo to simulate the battery disconnecting, the ps light turns off and back on.
I just tried removing the power button cover to press directly on the button, but no luck.
Is there any way to check if it is indeed an issue with the motherboard? I know that it at least somewhat works since it shows me a light on the ps button, which means the power goes from the motherboard to the ps button.
por
@zeyroxfame Ah, was already afraid for this. It is motherboard related... Something is broken there. I would replace the motherboard and see how that goes... Sorry!
por
Adicionar um comentário
