Ir para o conteúdo principal
The Meta Quest 3 mixed reality headset was released on October 10th, 2023 and is the direct successor to the Meta Quest 2 and in many ways the spiritual successor to the Meta Quest Pro.
What material is the heatsink
I want to see if liquid metal is possible for the quest 3 since i want to overclock it
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Howdy there dan.
The heatsink is aluminum, so it is not advised that you use liquid metal since it will react with the liquid metal.
Best of luck to you!
Esta resposta foi útil?
Pontuação 3
3 comentários:
Thanks alot ill stick with thermal sheets and yeester paste or arctic mx4
por
@dandan0 If you're looking for reccomendations iFixit's thermal paste is pretty good, and is relitivly inexpensive.
por
I have some already its just those have better thermal conductivity
por
Adicionar a sua resposta
0DanDan0 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 275
